broke blaze
Discussion in 'The Garage' started by Randy92782, May 2, 2007.
  1. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,287
    Arcadia, MO
    yep it didn't last long with the 1/2 ton stuff. on to 3/4. front wouldn't pull for some reason. have yet to check it out. front and rear driveshafts were spinning though:doah:
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    You prolly know this all ready but 1/2 and 3/4 ton front ends are the same- cept one has 8 lugs. Your hubs messed up or you think it's the gears?
  3. Randy92782
    Mar 25, 2007
    16,287
    Arcadia, MO
    yeah i have 8 lug front and rear end. i have no idea whether it's the gears or the hubs on the front that is broke. haven't took off the diff. cover yet. the rear i know for sure it's the spiders. but nothing else seems to be broke.
  4. Ancient4X4
    Ancient4X4 Registered Member
    Feb 25, 2005
    82
    ND, USA
    It broke in sand?
  5. Randy92782
    Mar 25, 2007
    16,287
    Arcadia, MO
    unfortuantely yes. it was a river bank and the sand was just sittin on top of the rock underneath. it did good til it hit the hard stuff. i always had problems with the rear end leakin and didn't check it. but it still had enough in it when i pulled the pan. idk i was gettin on it pretty hard. i think it would have held up if i hadn't changed over to manual and 205. there's always a weak link
  6. 87K506
    87K506 1/2 ton status
    Sep 18, 2005
    536
    Pitkin, Colorado
    sand can kill axles...I know trucks can get to hopping real bad in sand..
