broke down....need help from engine gurus
Discussion in 'Other Rides' started by eds77k5, Nov 10, 2002.
  1. eds77k5
    eds77k5 1/2 ton status
    Oct 19, 2001
    383
    washington state
    wifes car, 89 buick lesabre, 3.8 engine, water is leaking out just below the water pump, seems to be comeing from a plug of some kind, hard to see because it is just below the pulley, anyone know what this might be and what it would take to fix, any help is much appreciated, thanks /forums/images/graemlins/mad.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Sounds like it might be a freeze plug. You're going to have to pull everything out of the way so you can see for sure what it is. Providing it is a freeze plug, I usely drill a hole in the center and use a pick or pointed end punch to pop the old one out, then I like to use a piece of emory cloth to to clean the surfaces, and tap a new one in.
  3. eds77k5
    Oct 19, 2001
    383
    washington state
    ok thanks, sounds like it might be /forums/images/graemlins/frown.gif
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I have a different opinion...it's the water pump itself. Water pumps are equipped with a throwout bearing, and when the bearing goes out, coolant will leak out of a little hole in the bottom of the water pump. This happens to every water pump. The bearing goes after many miles. It's not unusual. You need to get a new one, replace the old one, and you'll be running like new.
    It would be very odd to have a "freeze plug" on the front of the engine.
  5. eds77k5
    Oct 19, 2001
    383
    washington state
    yeah, i looked at it some more and couldnt really tell for sure that it wasnt just comin from the water pump, i grew up with old cars, the newer ones just plain suck for workin on, thanks /forums/images/graemlins/smile.gif
  6. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Sounds to me like a water pump weep hole as well. There are many ways to tell if it is the w/p. If the pulley is tight but has play it, or there maybe a corroded trail the coolant left on the w/p.
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I second that, it's the weep hole, that usually means replace the pump with a new one.
  8. eds77k5
    Oct 19, 2001
    383
    washington state
    it werent weepin, it was flat out cryin, water was runnin out as fast as i poured it in, its vets day and im takin the day off, sent it to her mechanic to be repaired, thanks for the info, it helped /forums/images/graemlins/cool.gif
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You might also check out the bypass hose(little hose between the pump and intake manifold) and fitting. The fitting on my Bonniville with a 3.8L was made out of plastic. It cracked and leaked similar to the way you describe.
    GM makes a upgraded metal fitting to replace the POS plastic one. The guy at the parts counter told me the plastic ones break all the time.
  10. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Im thinkin its the wet hole too. You might wanna jiggle somethin around down there to see if it really is wet. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    Don't scrap it, JB it!!
  11. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    [/ QUOTE ] LMAO!
