Broke hard brake line on passenger side, how do I fix it? FRUSTRATED!
Discussion in 'The Garage' started by FreedomIsntFree, Sep 1, 2005.
  1. FreedomIsntFree
    FreedomIsntFree 1/2 ton status
    Aug 23, 2005
    124
    DFW, TX
    So I was trying to loosen the fitting where it comes together on the frame rail and I snapped the hardline on the passenger side.
    Please tell me I don't have to buy a whole new hardline that goes from the master cylinder to the front passenger side?
    Can't I just use a coupler or sometype of fitting to splice it back together? I'm really upset that I broke that line. :angry1:
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    if it broke right at the nut you ought to be able to cut it, flare it and reuse it.
  3. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    not so bad....
    You can buy a line with fittings installed at a parts store for about 5-10 bucks--OR you can cut and double flare it and add a small peice--don't be tempted to use compression type fittings!--they are not designed to handle the pressure,and could fail at the worst moment!...
    I feel your pain--I have to change both of the rubber hoses on my 79 C10's front brakes--and I'm hoping I dont have the same problem as you--but with my luck,I will! :doah: --fix it right and be safe!--if it snapped off that easy,its probably rusty somewhhere else too,and ready to pop. :eek1:
    I'd not bother splicing a new peice in--replace the whole line back to the juntion block on the front crossmember..bring the old line with you,they are different threads at the junction block sometimes--you might need a brass adapter fitting.. :crazy:
  4. FreedomIsntFree
    Aug 23, 2005
    124
    DFW, TX
    Broke it about 3/4" past the nut on the hard line. Can I just cut the line straight, slip the fitting over it and flare the tip? I think that's what you mean.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yes that is what i mean
  6. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Just make sure you use a double flair...a regular flair won't hold.
  7. FreedomIsntFree
    Aug 23, 2005
    124
    DFW, TX
    I'm gonna head to a place called Stuart Hose and Pipe in the morning and just buy some lines. There is a block on the frame. So I can just go from that to the frame near the rotor. So at least I don't have to replace all the way from the master cylinder to the rotor.
