broke my dana 44
Discussion in 'Pacific Region' started by leadfoot067, Jan 19, 2004.
  1. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    for some reason 5 of the ring gear bolts came out..and the other 5 broke .....anybody else aver have this happen? and will it hold with just 5 bolts??(cough cough)... /forums/images/graemlins/ignore.gif
  2. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I had this happen 3 years ago. I had a 44 front in my truck, and it started all of a sudden making noise and acted like it was binding up internally. All my ring gear bolts had backed out and caught and broke off (the heads).
    I don't know why it happened, but it did. I just swapped in another whole axle that I had.
  3. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    Never use the bolts that come in the install kits, always reuse or buy new Spicer bolts. I don't know why, but even after cleaning them with brake clean, letting them dry, using red locktite and torquing them to spec we have had more than a couple of problems with them backing out while I worked at 4WPW. I've done more than a couple sets of gears /forums/images/graemlins/wink.gif and won't do it any other way. That really sucks about your diff. Did it do any damage to the carrier, gears etc.? I may have some parts for you.
  4. leadfoot067
    May 14, 2001
    1,563
    well this was just the kind of excuse i needed to buy a 60....so thats what ill do with my taxes this year.... /forums/images/graemlins/thumb.gifthe carrier seems to be fine....basically the 44 needs a total rebuild....its full of muddy slop,and the pinion bearings are gone also....so i guess ill just part the 44 out...
  5. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    oooooo ooooooooooooh pick me pick me!
