Broke My Engine $#@%!!!
Discussion in 'The Garage' started by walla2k5, Nov 21, 2005.
  1. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Had my Blazer on the road for 2 weeks and broke 2 pushrods,bent 2 others...:mad:
    Yes, I was thrashing the %$#@ out of it.Now I get to make a decision, just fix it or go BIG BLOCK. I have a line on a 79 C20 w/454 for $800.Sorry about the rant...
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Blowing up your engine is just motivation to go bigger and better...but you should be realistic about your solution, if the big block is good as is and you can afford gas go for it, if not, pushrods cost nothing and while you're in there, change out the heads, cam and intake for some more power!
  3. keifer
    keifer Registered Member
    Nov 1, 2005
    16
    MD-Phoenix someday
    As to which one, the small or big block, would depend on what the truck is used for. Was the cam replaced for one with higher lift?
  4. walla2k5
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Don't quote me but,I think the reason the pushrods went is oil pressure,correct me if I'm wrong.Oil pressure drops,lifter collapses= bent ,broken pushrods...The 454 has 40K on it,rebuilt.Gas mileage doesn't bother me since it's not a DD.Maybe new oil pump, new cam/lifters and pushrods might be in order...:dunno: In another week or two I'll tear it apart and see WTF...
  5. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    If you are referring to the truck in your signature line, by all means, go BBC................. good luck getting an engine in and out of that truck though ;)
