Broke my radiator drain plug now can't get it out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Sep 6, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Broke my radiator drain plug now can\'t get it out
    It was in there crooked, since I couldn't get it out with my hand I had to use a crescent wrench. Didn't hold up to that very long now it's about half way in there and I can't grip it with anything. Does anybody know how I can get it out?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: Broke my radiator drain plug now can\'t get it out
    <font color="green"> Probably have to use an easy out. If that doesn't work then you may have to take it to a radiator shop to have the fitting cut off and a new one brazed on. </font color>
  3. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    I have some easy outs, but they are my dad's and I have never used one. What is the proper way to use one?
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You just drill a hole in the thing with the right size bit, then put the easy out in the drill and try to back the broken piece out of there. </font color>
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Do you have, or have you used vice grips to try and get it out. I had to do that on a demo car once.
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    You could always take off the lower radiator hose to drain the rad, and then put it back on...doesn't fix the problem, but gets the job done.
  7. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if it's not leaking I would leave it in there. you can do as mentioned and remove the radiator hose to drain it, or I usually put a piece of 5/16 hose down in the tank and siphon it out. with the drain right by the steering box it always seems to make a mess draining it.
