broke my steering sector end cap
Discussion in 'The Garage' started by DERBINATOR, May 17, 2004.
  1. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    I did a hydrualic assist steering and took it out for the first time wheelin. I put the fittings in the alum. endcap and plate on top. I had a piece welded on to the endcap and drilled and tapped for 1/4 npt. everything was working great(best steering I've ever had) when all of a sudden it was gone. It broke or cracked right along the edge of the weld then headed for the edges of the cap. probably 2 or so inches long. I am wondering if the weld could have weakened the endcap or do I have to much pressure? Anybody have any ideas to try , check, what to look for?? /forums/images/graemlins/1zhelp.gif
  2. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    Built a new endcap tonight out of 6061 billet. So if it was the weld- problem solved- if it is to much pressure probably moved the problem somewhere else /forums/images/graemlins/dunno.gif
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I'm not sure but interested. Somebody help this guy out TTT /forums/images/graemlins/peace.gif
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    You could have possibly put your fitting too far into the cap. The moving parts in there could have put too much pressure on it/touched it and caused it to break. There is a company called EMSoffroad.com in pennsylvania. They make a billet cap with the fitting for $60. Good quality stuff too
