broke off axle vent tube, how to fix?
Discussion in 'The Garage' started by 87sm465np208, Sep 28, 2002.
  1. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    broke off the steel vent tube on a 10 bolt axle, the little 1\2 inch steel part clean off, i need to put on a vent, how do i fix it? please help, im in dire straights here /forums/images/icons/frown.gif
  2. Mikeyg79
    Mikeyg79 Registered Member
    Aug 3, 2002
    83
    I'd use penetrating oil, and an easy out to try and remove whats left of it. A cheap replacement can be made with a threaded barb fitting (look at NAPA or a hardware store)
    Mikey
  3. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    EZ out to remove the sleeve and tap it for a 1/4 pipe thread and put in a nipple to attache the hoze. you prolly want to pull the cover and stuff a rag in there to catch the metal shavings b4 you start.
