Broke some teeth the other day
Discussion in 'The Garage' started by bad_bo_ti, Sep 18, 2004.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    [​IMG] Broke 4 teeth on the ring gear on my 10 bolt in the 93 chevy, what would be a good axle upgrade other than the 14ff, i want to stay 6 lug and dont want to spend a lot of money either since i blew the transfercase up too and have to replace it /forums/images/graemlins/angryfire.gif other pics can be seen in my photo gallery
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    14 Bolt Semi-Floating would work /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif Not sure on years to get it from though
  3. bad_bo_ti
    1,027
    OhiO
    thats what i was thinking, will my stock rims fit?
  4. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    A friend of mine just put a 6 lug 14B semi-floater in his Yukon. Works great, kept his rims, I can't remember if he had to change his driveshaft though.
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    That ring gear sure is shiny! /forums/images/graemlins/eek.gif
  6. bad_bo_ti
    1,027
    OhiO
    is shiny bad?
  7. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    how in the hell did you do that?
  8. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Re swapping in 14 bolt SF.
    your stock rims fit, your e barake cables will fit, but you need a conversion u joint and need to get or make spring plates. I just mad some out of 1/2 inch plate and used normal round ubolts pointing up instead of the stock square ones pointing down.
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    ff14b with spacers/adapters?
    j
  10. bad_bo_ti
    1,027
    OhiO
    /forums/images/graemlins/dunno.gif i have no clue
  11. bad_bo_ti
    1,027
    OhiO
    [/ QUOTE ] rim center has to be 4 5/16 mine are 3.5 dont want to have to buy rims.
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Its just oily.
