Broke the shock off...suggestions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zakk, Oct 26, 2001.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    broke a shock mount scouting for a mud hole. It look like a bolt snapped and now it is dangling off the 14B. can i just run a grade 8 bolt through the eye of the shock and through the frame? or take it off, ruff it for a bit and have someone relocate the shocks? any help is appreciated, as it is to rain here Saturday nite [​IMG]
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    it's pass. side. will a new bolt work? i couldn't really see in the dark.
    -Zakk
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You probably could run a bolt threw the frame but that would only be a temperary fix in my mind. Steve Frisbie has a new rear shock mount system out. Its a little expensive, but looks stout. Its like $200. I'll find the webpage and get back to you.
    My Chevy isn't broken, its just out of gas.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    is the shock mount welded to the frame? i cannot find the chilton's manual...it dark...mud coming...AHHHHHHHHHHHH!!![​IMG]
    -Zakk
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Any given auto parts should have a replacement shock stud for a couple bucks. Just pop the old one off, and install the new - takes about 20 minutes or less, depending on rust.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  8. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    The it is not welded to the frame, it is rivited. After I broke mine, I replaced the mount and had it welded to the frame.
    Derf00
    "A WISE MONKEY NEVER MONKEYS WITH ANOTHER MONKEY'S MONKEY."
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    so you suggest i get a shock stud suck as Pugsley is suggesting them weld it for more strenght??
    thanks to all
    -Zakk
  10. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    <a target="_blank" href=http://www.mooffroadoutfitters.rockcrawler.com/whats_new.html>http://www.mooffroadoutfitters.rockcrawler.com/whats_new.html</a>
    here that link to frisbes page
    high
  11. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    If it is the pass. side it is just a bolt bolted to the frame and the shock fastens to the outside. The drivers side is the one rivited on. I may have one more shock mount bolt laying around, I just sold 2 to Wayne for his rig cus the old shocks on his wanted to keep them for themselves,LOL. I bought 4 cus I was doing duals but changed to the inboard set up.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    is there a "special bolt" or can i just get a grade 8 and slap it in? i tried getting the broken one out, but no go...
    -Zakk
  13. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Just using a straight bolt won't give the shock much of a shoulder to keep it from bashing into the frame - you really need to get a new shock stud to do it right. You could get a really long bolt and use 2 nuts and fender washers to make a shock mount out of it, but it wouldn't be as strong.
  14. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i went ot kragens and they said nothing like that existed and to have it welded...is a "shock stud" the correct nomeclature for such a part? I guess i'll try kragen's tomorrow, or ask 55Willy to sell me and extra one of his [​IMG]
    thanks
    -Zakk
  15. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Trade ya the bolt for your dana 60????[​IMG]LOL
    let me run out and see if I have one more left............
    55 Willy's
  16. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    After running through the books and looking over the inventory, checking the warehouse, asking personal, filling out paperwork and doing numerious calculations I have determined that I do indeed have one left....Actually all I did was look on my workbench and found one,LOL
    55 Willy's
  17. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    after my people called your people, did lunch and hashed out the logisitics, they decided that i should try to ask kragens tomorrow and then get back to you tomorrow afternoon.[​IMG]
    thanks 55...will be in touch...
    -Zakk
  18. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    After a careful scrounging through a stack of receipts, here's the Checker/Shucks/Kragens part # for it - Motormite #31001. $5.49 as of 12/5/2000.
  19. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you guys are awsome...
    this board is the electronic equvilent to a monestary.
    helps everyone and anyone with whatever they have
    again, props to EVERYONE!
    -Zakk
