Broken 241 extension housing
Discussion in 'The Garage' started by 1979jimmy350, Dec 22, 2005.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    What would cause the extension housing to crack off a 241 transfers case? My buddy just changed the ujoints in his 91 because the rear ones failed after he changed them he drove it around the block and a bunch of noise came from the drive line and when he reomved the drive shaft the extension housing came off with it. I just don't want to put every thing back together for him and have it happen again. Luckly i had a extra extensionhouseing from a 233 transfer case i was suprised that they fit and were even the same gm part number
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    It sounds like when the u-joint initially went bad it might vibrated enough to crack the extension housing. It eventually failed after some use (coincidentally after the u-joints were changed)????
    Apparently this is common???
    http://coloradok5.com/forums/showthread.php?t=148944
