broken axles
Discussion in 'The Garage' started by gmcjimmy4x4, Nov 6, 2006.
  1. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    I recently broke both front axles. All the drained out of the passenger side while parked on a slight incline. Maybe the axle slid out to far or do you think i need to replace the seals. They are not very old at all.
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    What piece exactly broke?
    -Harrison
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    I would replace the shafts and see if it still leaks. The shafts being broken may be making the seals leak and they may still be in usable condition. Good luck!
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    If the axle turned while binding on the seal then it is probrably junk. I personally would replace them now rather than putting it all back together to find it's leaking and needs to be torn down all over again.
  5. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    how much hasssle is it to replace them.Ive never done them before. Had the hole axle rebuilt 6 mos ago.
  6. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    what type of axle assy is it?
  7. 87BrnRsd
    Apr 21, 2003
    2,457
    Judging from his info, I guess its a 10 bolt. If so, its not really hard at all to replace.
    -Harrison
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Every axle that I have seen which broke an inner axleshaft has also trashed the seals.
  9. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    Both sides broke at the u-joint. how do you get to the seals and are they expensive?
  10. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    welcome to the club. :haha:
    you have to break the outers down to the knuckles, pull the shafts, then pull the carrier, then you can pop the seals out(cant remember if you use a long rod through the axle tube or if you can just go through the diff to remove/install.)
    less than $10 apiece
  11. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    thanks for the info, hopefully weather pending ill be tearing into it really soon.
