broken axleshaft front..now I done it
Discussion in 'The Garage' started by chillywilly, Jul 21, 2003.
  1. chillywilly
    chillywilly Registered Member
    May 26, 2002
    70
    northern maine
    At our last mudbog I snapped my lf axleshaft when the tire hit dry ground coming out of the pit.I went to install new shaft had to drive old one out with a sledge.Then when putting new one init would only just start to engage the side gears still needing to go another inch half to 2 inches.The spiders are welded in front for mud runs.Anyone else ever run into this? /forums/images/graemlins/1zhelp.gif
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Iv had that problem before,turned out the front end was bent.The drivers side axle tube was no longer going straight into the center housing so when I would try to slide the shaft in it didnt have a straight shot into the splines and wouldnt go in.Pull the carrier from the housing and see if you can put the shaft in it. /forums/images/graemlins/grin.gif
