Broken bolt in 14BFF yoke
Discussion in 'The Garage' started by MTBLAZER89, Mar 19, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I snapped off one of the bolts in my Yoke. The other three came out fine of course. Is it ok to just drill these and use a grade 8 nut and bolt? I know it was covered before, but the word "yoke comes up a LOT on a search /forums/images/graemlins/thumb.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    danny, we broke a bolt in nick (chevy4wds) yoke and when we drilled it out, we broke a bit off and had to swap yokes.. be careful when drilling it so that doesnt happen.. but yeah we used grade 8 bolts and nylock nuts and it works great, you may have to grind the backside of the yoke a little for clearance of the nut..
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cool but who's Danny? /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I ran into the same problem.
    Pretty much like you said, I drilled the holes out (all four of them) to 5/16" and then installed four bolts and nuts with lockwashers. It has worked well, so far. Oh, and like suggested, I took a grinder to the back of the yoke where the nut will be and gave it a little more clearance and made sure the nut will sit flush with the yoke.
    Good luck drilling through your busted bolt without having your bit wander off to the side...I've found the yoke material is a lot softer than a bolt/extractor/drill bit combination. /forums/images/graemlins/ignore.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
