Broken bolt in head . . . .
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spincast375, Nov 28, 2004.
  1. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    Prior owner broke a valve cover bolt in the head. Please suggest easiest way to get it out. It's almost flush with the head. Valve cover leaks, but not at this bolt.
  2. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    First shot would be an easy out. Drill a pilot hole and thread it in. Might not hurt to heat the area around the bolt to expand the area incase of rust.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Like he said. But smaller bolts can be stubburn to get out. If you can't get it out with an easy out. You can drill it out larger and intall a heli coil.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    After its out , go get some 1/4 " - 20 studs , that way you won't have to worry about it again after its heli coiled /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  5. dremu
    Feb 27, 2000
    15,963
    452
    East of San Francisco
    Weld a nut on top, and back it out like normal?
    If there's enough thread to center the nut on, you could then zap the center of the nut with weld ... minimal spatter/muss that way.
    -- A
