broken bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jmpd, Jul 21, 2000.
  1. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    I had a small little 10mm bolt to take of my fuel rail on my TPI. I broke a craftsman 10mm 6 point on it. the other bolts 3 came off easy. I tried an open end wrench, and it stripped the bolt, I then tried vise grips(rounded the edges). I drilled and then tapped with an easy out. The easy out broke. Now i can't get the bolt out(it is on the fuel rail and should be veeeerrrry easy to get out) I tried to re-drill the easy-out out but it is stronger than the drill bit. I think I'm screeeeweeed. I will probably have to grind the bolt head and easy out off then drill and tap the bolt...... any suggestions? I'm pissed
    Thanks in advance
    Michael
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    O yhea, those can be fun.. Go to the store and by a sharp cold-chissel(sp) and a flat-grinder. Grind a litle canyon on the bolthead and try to tap it loose using a hammer. You can also grind it flat again where the edges are rounded off. Allowing a second chance for the wisegripps.
    Hope I helped.
    <font color=blue>Espen88k5 at:http://www.espen.coloradok5.com</font color=blue>
