Broken caliper bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Aug 15, 2000.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I sheared the top off of a caliper bolt today right befor the threads and it still in the caliper rusted pertty good. I dont have a backout kit does anyone have any tips on getting the bolt out or is backout kit the only way...
    Brent
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    If you can't get to it with a pair of vise-grips I think you don't have too many options.
  3. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    Try heating the surrounding caliper area with an acetylne(sp) torch, not propane (not hot enough), use some liguid wrench or similar product prior to heating. Then get a good grip on it with vise grips should come out
    <font color=purple>Rick
    86 K-5</font color=purple>
    http://www.BigBadBowTie.ColoradoK5.com
  4. 78k5
    78k5 1/2 ton status
    Apr 25, 2000
    173
    Big Island, Va.
    The bleeding zirks were frozen on my calipers and I priced them they were only $12 each at Autozone. Probably less effort to get new ones.
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    The label on this bottle of liguid wrench say Flamable, so be carfull................
  6. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Its fried, I going to pull the knuckel and take it to a machine shop. Broke off just under the caliper so I cant get at it, oh well thanks anyway!
    Brent
  7. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    I busted one a couple of years ago, turned a one day job into a 5 day job. We tried to like hell to get that bolt out. If I remember right the THREADED part of the bolt is in the dust cover/backing plate on the inside, not the caliper itself, I ended up cutting the bolt up to get the caliper off. Then took off the rotor and the dust cover with the broken bolt in it, tried an easy- out and liquid wrench ,no luck, so then tried the torch method, again no luck. So then I figure since I have it off the truck I'll take it to a machine shop, they tell me 80 bucks, plus the drill bits that break because I had heated and hardened the metal. Well heck, a new dust cover/ backing plate from G.M. is probably cheaper than that, so I check it out.....160.00 new! So now I figure I'll go the wrecker route and phone around , nobody seems to have one, which I find hard to believe, that is till I tell one guy the retail price from G.M. " Oh, well gimme your number, I'll see what I can do!", ya now he figures he can hose me on the part, see ya buddy! Anyway I ended up paying 80.00 bucks to the shop for a heli-coil and 10.00 for a new bolt 4 days later. I coated those puppies with anti seize and put it all back together, but that's my story hope you have better luck with yours!
    MIDCAN k5 " DIG A HOLE!!!"
  8. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    I would cut the bolt and buy new calipers 12.00 at autozone. 78k5 is right it would save alot of time and money.
