broken D60 35 spline hubs!
Discussion in 'The Garage' started by great scott, Mar 12, 2003.
  1. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    Just broke my third 35 spline hub in omly 8 months. First one was on the rocks then today pulling a freind out of the mud the right side let go and a bit latter the left. So should I ditch the hubs(life time warnty) and get those block outs that relace the hubs. What are they called? What part #'s. Are they stronger? Pro's and cons?
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I believe they are called drive flanges... thats all I know about them. I do, however, recall hearing that they don't break as easily because there are like no moving parts in it, but you will always be locked...
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    how in the hell are those breaking? i tried to find a list of mods on your rig but i couldnt. 3 in 8 months? holy sheep sh!t
  4. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    pros and cons- you shouldn't break anymore other than the axle shafts and u-joints. and you can't disengage the front anymore with them.
    Warn part #39346
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yow. Makes sense, the holes are larger, so no surprise you'll pop more of them. I've been looking for slugs (aka drive-flanges) for a while now...
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yep, the slugs are supposed to be alot stronger. So is Warn taking back your broken hubs when you warranty them? If you have any of them left I'd be interested in getting one from you. I'll just get a new lockring for it and use it as a trail spare since I may have the same problems with my 35 spliners... </font>
  7. great scott
    Dec 31, 2002
    333
    Utah
    here's a tech type shot of my ride. [​IMG]
  8. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Lets see if i understand, by holes, you are talking about where the stub goes in the hub? So when you go to 35spline outers, you are making the stub stronger and the hub weaker?
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The hole is bigger for the 35 spline stub, the outside is a constant, so the surrounding material is thinner. That could certainly lead to more broken hubs, assuming that's what broke. Or, it could have stripped, which would be less likely with a 35 spline hub...
  10. great scott
    Dec 31, 2002
    333
    Utah
    4WPH is warrenting them. So thats part of my debate, mabey I should just buy a spare hub, but no matter how easy to fix I dont like breaking.
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    If you run tall skinnies, the lockouts are right there waiting eat a rock. Mine will get flanges when the Michelin XL's go on /forums/images/graemlins/thumb.gif
  12. great scott
    Dec 31, 2002
    333
    Utah
    with my 18" wide Boggers that's not a big concern.
