Broken diff bolt
Discussion in 'The Garage' started by lochenjons, Apr 5, 2007.
  1. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    I was pretty sure there was a thread on this but I couldnt find it. My rear diff was leaking a bit and I had popped the cover off not that long ago so I go to see how tight the bolts are...not tight at all. So I tighten them all down more. Then I deicde to tighten the bottom one down just a little bit more...and it snaps off :doah:. Anyone got a 14b for sale :D?
    EDIT: wow long day... if you read the post before I edited it....
  2. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    I snapped on off in my rear 10 bolt as well. I just left it like that, but I haven't changed the diff fluid since. I think it'll be fine, once I pull the cover again, i'll try to get pliers on it and get it out, and just put a new bolt in there. Once I get a good job and some $$$ I'm going for the 14 bolt and D44 also.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Are you talking about a ring gear bolt or a carrier cap bolt?
  4. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    No just the cover, no biggee. More of a rant on my part than anything else. I had a question but then I realized it was really really dumb :doah:. I was surpised how little it took to break the bolt tho, and I had just broken another one from somewhere else :mad:
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Oh ok, a cover bolt. Those are a 3/8" x 16 bolt and can take 35 lbs torque. I usually only tighten them by hand if using the stock cover and if a thick aftermarket cover then i will break out the torque wrench and torque them to usually about 30 lbs.
  6. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Oh thanks, knowing the size will save me some effort. I always tighten them by hand (dont have a torque wrench) and I barely gave it anything. Oh well...now I'm gonna have to pull off the whole cover again to be able to get whats left of the bolt out.
  7. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I did the same thing when I was filling up my 14ff...I filled it up...slathered some RTV on it and put the cover on.
    When I started to tighten the bolts I was going in a criss cross pattern and got them tight (by hand) then made one last trip around just to be safe and I snapped the head off of one of them...I didn't mess with it and I haven't had any problems.
    You can take a dremel and slot the top of the bolt...then use a flat head screwdriver to unscrew the stuck part of the bolt...
    Or try drilling it out and re-tapping the hole (might have to go to a bigger bolt...)
    Or has anyone tried drilling it out and using a heli-coil?
  8. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Ha never thought of that, Ill have to give that a try
  9. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    yeah we used to do that all the time when I worked at the local hobby shop...whenever screws were stripped to the point that they would have to be replaced we'd just slot the top with a cut-off wheel then use a flat head screwdriver to unscrew the stud.
