Broken dip stick part II....un-cut!
Discussion in 'The Garage' started by Avery4jc, Jun 9, 2006.
  1. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Ok you all know the story of the broken dip stick and how it caused me a ton of grief with my truck. I took care of business and dove into a project that was a touch bigger than I thought it would ever be. Now that I did it I'm glad that I did and was proud of myself....
    So then I took it out for a spin as we all remember and when I got home I found that I was puking oil everywhere and smoking a ton from it getting all over my exhaust (which took forever to clean up and burn off).
    I came on here and asked for some suggestions as to what I should do and before I tried them I decided to try and tighten up the bolts to see if that was all that my problem was. To my surprise it stopped the gushing and I was set to go again.
    My dad and I have put some miles on the truck since then (most of them in a single day when we had a ton of errands to run on Wednesday) and every time we stopped I noticed that there was a few drips under my truck. I didn't think anything of it because I figured that it was only some oil that was dripping off of everything when I gushed it all over the underside of the truck, I was wrong.
    So today I couldn't take it anymore, I got on some old clothes and pulled the truck up into the grass and went to town cleaning the underside of it so that I could start it up, move it and then wait to see where the leak was coming from. To my surprise it wasn't from the pan/gasket area that I just replaced, it was from this.....(see pics)
    What should I do?
    -Avery
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    keep searching... the leak isnt coming from there. starters dont have oil in them.
    i'd almost bet on a leaky intake, or possibly a rear main seal.
  3. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    I'd like to know where your leak is coming from as well. I have the same drip off of my starter. I know I have other leaks too, but I've been trying to pinpoint them all.
  4. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    My guess is that you have oil inside the flywheel cover, and the flywheel is slinging it all over the inside of your flywheel cover. You should remove the flywheel cover and clean it. Then, before you reinstall the flywheel cover, drive it around for a little while without the cover OFF to see if you have any further leaks in that area.
  5. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    exactly my thoughts.
  6. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I messed up and used the word "on", when it should have been "off". I edited the post to read correctly.
  7. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I saw your edit and it makes much more sense. So I should remove the cover, clean it out and then replace the cover before I drive around. Then when I get back see if I still have that leak?
    If I do have a leak won't it just come right back when I bolt everything back on and run it around? Or do you think I had some oil in there and I just need to clean it out?
    -Avery
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    dude, it made more sense when you said "on", as you used the word "without". kinda wierd to say "without it off" particularly in light of what you're actually trying to say. need a beer? :D :wink1: j/k.
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    the point is that if you take it off, clean everything up and run it for a while, you'll have a better idea where the leak is actually coming from when you go to look at it again. you'll be fine running w/ out your cover. alot of covers are plastic, so they aren't durable anyway. i might be slightly concerned if i were going to be driving thru really high grass or doing any sort of wheeling where i might get a rock up in there, but driving around on the streets for a while is fine. some guys on here don't even have a cover at all!
  10. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
  11. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    yep, yours is metal. if you take it off, you'll see your torque converter (often orange or blue) attatched to your flexplate (flywheels are for manuals, flexplates are for autos). we're on the same page. i'm just saying that its not rare to see those covers made of plastic, which is much less durable than your metal one.
  12. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    really? that seems like a terrible place to put plastic. I'm only used to working on my truck in depth like this so I had assumed that they were all metal.
    The oil pan has two drops in it, one in the front for the *fill in the blank* and one in the back towards the tranny for the *again, fill it it*.
    If there is a leak in the one going towards the tranny it would probably drip down between the back of the oil pan and the front of the tranny (on that torque converter cover) until gravity stopped it at the lowest point, my starter....what do ya' think?
    Here's a second question, should I even care? Are a few drops here and there really going to hurt me? If I keep an eye on my fluids and top off/replace when they get low I think that I might be wasting my time finding a leak this small.
    -Avery
  13. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I have some cold ones chillin in the fridge right now. Soon as I finish dinner, I am going out to wash my truck in the driveway. I will have the hose in one hand, and a cold one in the other. :D
    Any hoo, I think most of you have decipherd what it was I was trying to say. Oh yeah! To be technically correct, I should have said "flexplate"...instead of "flywheel".
  14. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Probably the rear main seal leaking. Mine leaks too, no biggie-just check the oil level more often.:D
  15. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    That's what I wanted to hear! Screw the oil leak, lets grab a...well beer for all ya'll and soda for me and kick back. I'm tired of crawling under there for now and I really don't care anymore. I'll just keep a close eye on it.
    -Avery
  16. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i don't really understand what you're saying/asking.
    if i understand you correctly, i believe you are correct. the oil could easily get inside your flexplate cover as this butts up to where your crank comes out of the block, so if your rear main seal (the one that seals around or under the crank - depends on your engine) is leaking, then this leak could easily get inside that cover, where it would run down and onto the starter.
    it's not going to hurt you as long as you watch it. it might ding your pocket book a bit, but probably not that much. it would drive me freaking crazy tho. however, to fix something like a rear main seal, and to do it properly (as opposed to the hillbilly way) you have to pull then engine. you could potentially drop the oil pan and crank and all the crap involved with that while the engine is in the truck, but it's not proper and, IMO, not nearly clean enough.
  17. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    crap, forgot to add this....what should my pressure guage be at? Mine is anywhere from 30-45 depending on my rpm. Is that ok?
    -Avery
  18. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    pressure guages are notoriously wrong, as with all of the guages in our trucks. that pressure sounds kind of low to me, but you're probably fine. i think 60 psi is average - can someone verify that for me?
  19. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Both of my trucks (1991 V3500 Crew Cab) and (1985 K30 Dually), run at 50 PSI when warn and idling, but climb to 60 during cold starts, or when driving down the road. 30 to 45 PSI is OK for a Chevy V8. They can live on that.
  20. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Your doing fine with the PSI, a small block chevy only needs 10 psi per 1000 RPM...
