Broken Front Shock Mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JP's K5, May 7, 2003.
  1. JP's K5
    JP's K5 Registered Member
    Mar 19, 2002
    38
    Northern Nevada
    Has anyone else ran into this problem? The passenger side dual shock mount on the axle broke off completely. This is not the first time, it also broke on my 1/2 ton axle. A simple weld cures the problem but what is a permanent fix?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Get rid of the factory lower mounts and weld on some confer mounts instead. The confer mounts are much thicker than the factory ones and there are 3 pieces to them so there is a steel plate on both sides of both shocks.
