Broken greasable spring eye bolts?
Discussion in 'OffRoad Design' started by 6.2Blazer, Jul 14, 2003.
  1. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Broke a front greasable spring eye bolt this last weekend wheeling. When the bolt broke it pretty much took out the entire bushing and the sleeve. Is this fairly common, or is there some other part going bad that could have caused this?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'd like to take a look at the bolt, it was probably a bolt failure primarily. I'm guessing it was a bad bolt to start with.
    Give me a call and we'll trade you a new assembly for the busted one so we can look at it. Was it one of the newer Gr8 bolts? We've never had a problem with either one but you're more likely to break a Gr5 bolt. I'm assuming it was on the driver's side?
  3. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I'm not sure if it was a "newer grade 8" or not, I've had them for a few years now.
    Yes, it was the driver's side.
    It would be awesome if you would replace it. I only managed to recover half of the bolt, couldn't find the other half. I will be calling you later on this afternoon to work out the details.
  4. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Steve,
    I had one break about 2 months ago as well. It broke on the thread end just inside the shackle. I think mine just reached its service limit. It was pushing 4 yrs of hard wheelin. It broke clean like a typ grade 8 will when over-torqued.
  5. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Sent a couple of pics of the broken bolt and sleeve (they will show up in a couple of different messages since all the pics were too big to put together).
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I don't know what happened to the bolt from looking at the pics, it looks pretty mangled, I'm going to say that bolt had problems from the start.
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    ya know... i keep hearing about this stand up guy you are... and i have only bought from ya once. wish i had money to buy from you and a few others a lot more. because of things like this, i really dont mind spending a few dollars more on your products.
    keep it up man.
    Grant
  8. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Is the greasability making the bolts weaker? They are hollow after all, aren't they?
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    All I remember from school is removing metal from the center has less effect than removing it from the outside. That is why racers use gundrilled axle shafts rather than going w/ a smaller size to reduce weight.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Now that's unbeatable customer service !!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
