broken hub
Discussion in 'The Garage' started by TULSAK5, Feb 14, 2003.
  1. TULSAK5
    TULSAK5 Registered Member
    Feb 20, 2002
    93
    Broken Arrow, Oklahoma
    I broke a hub last night pulling another truck out of the mud. My question is; Is there a "fusible link" in the hubs that break or do I need to replace the whole hub? I remember Steve Frisbie fixing one on the trail up at Disney but I didn't pay attention at the time. They are warn lockouts on a 10 bolt. Any help is appreciated.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Warn Premiums come with a "hub fuse" that is supposed to give out before anything else breaks, if that helps.
    John
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you don't have Warn Premium hubs with the fusible link, then no there is no fusible link in your hubs, and you will most likely have to replace the whole thing. If you switch to Warn Premiums you can get the fuses in them so hopefully they will strip before a hub, axle, a R&P break. If you run a front locker other then an ARB you can run them though.
    Harley
  4. TULSAK5
    Feb 20, 2002
    93
    My bust, I have superwinch hubs not warn, so I guess I'm in the market for a new set.
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    the warn premiums can be bought for about 70 bucks is the best ive seen.the warn fuses are 20 bucks extra.they are just thinner metal than the standard lock ring and will brewak easier than the ujoints or shafts.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    That is assuming that the tires are pointed straight or near straight. If they are turned, then all bets are off, and the ujoint will probably be the weak link. If you have superwinch hubs I believe that they have a lifetime warranty and you can get another one free. Personally I would buy the Warns and fuses, and keep the superwinches for spares.
  7. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    then just add some ctm u joints and warn axleshafts and all will be good.thats assumeing you want stuff that is lifetime guaranteed.i just wish i had the money for that stuff.i have the hub fuse in my hubs but have never broken one.luckily i havent broken a ujoint either.theres alwasys the next wheeling trip though /forums/images/graemlins/thumb.gif
  8. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Where is a good source to buy Warm Premiums with the fusible link and what are the part numbers?
    Ross
  9. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Only if you swap in aftermarket shafts & joints. The fuses have a higher breaking strength than the stock shafts and are stronger than a 5-297/5-760 joint when turned.
  10. TULSAK5
    Feb 20, 2002
    93
    I just did an internet search. The cheapest place I found was www.accessconnect.com. Regular Warns are 60 bones and premiums are 80 bones with free shipping. Does anybody know a cheaper place?
  11. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Try your local parts store. About the same price, but no wating.
