BROKEN KEY IN MY REAR? I THINK.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gumneck, May 2, 2003.
  1. gumneck
    gumneck Registered Member
    Feb 6, 2003
    89
    VA
    thought that get some attencion. Hard to tell via looking but I think the stupidsh..head owner of my blazer before me broke a key off in the rear window key cylinder. I know I can't put my key in it all the way like its supposed to. As far as seeing anything it looks like small tip of key could be in there but nothing definate. Anyway, have tried a small parts pick, no luck.
    Looks like you have to go thru backside of tailgate to get at lock cylinder. Anyone care for tip offering on this. Tks in advance.
    Tom
    1991 BLZR
    /forums/images/graemlins/ears.gif
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You can roll the window up with the 'gate down by pushing down on the drivers side latch on tailgate until it clicks twice, then the tailgate thinks it's closed and you can roll the window out. The glass needs to be supported though, I use some trashcans with a blanket over them.
  3. gumneck
    Feb 6, 2003
    89
    VA
    Blazerguy,
    Tks reply. You've lost me. Real easy to do.
    I can use the switch on dash to go up/down no problemo. It just seems like there's remnants of a key in the lock and I can't put my key in the rear window key switch. I thought it would be nice to be able to do that thinking you dont have to start up the truck to get window down. Wondered if I have to get cylinder out to remove broken key.
    Tks again,
    tom
  4. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    it will pass /forums/images/graemlins/eek.gif
  5. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    You might Scream /forums/images/graemlins/shocked.gif
  6. dyeager535
    26,977
    tailgate clicky
    Heres a bit I did on the tailgate. Not sure if you can disassemble the lock cylinder enough to actually get a piece of key out of it, kind of doubt it, but since you'd have to pull it anyway, might as well try, right?
