broken lower shock mt.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by carolina custom, Feb 10, 2002.
  1. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    well I broke my lower shock mount on my front 10 bolt today. I have the quad shocks. I have been planing the upper ford shock mt. and the rs9012s. Whats the best fix for the lower?
    84k20,18:1- 6.5td,400/208,4.10,4",35"s
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    weld it back together with a gusset on it, or replace it.
    <hr></blockquote>
    What do you mean, Where did I get it??...I <font color=blue>BUILT</font color=blue> the damn thing!!
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    When that happened to me, I was lucky, and a 4x4 shop in Phoenix made the reapir kits for this problem. But since then they have discontinued this kit. My suggestion is go to a good fab shop in your town, and they should be able to fix it for you. If you know someone who welds, and the bracket is fixable then have them do it. Just make sure to reinforce the broken side and the other side too so it doesn't break and have to deal with the problem again.
    P.S. After the mount is fixed you can remove the shorter shock. It will reduce stress on the mount, and improve your ride too.
    My Chevy isn't broken, its just out of gas.
  4. carolina custom
    Dec 29, 2001
    161
    Mt. Pleasant SC
    The single shock sounds like a good idea. The mounts appear to have been reapired before with plates samwitched on the outside. they are pertty ripped and mangled. It looks like I will probably have to cut off the whole mount. I will probably fab some out of 1/4 plate and weld triangle gussets perpendicular between the shock mount and the axel tube. Is this a good idea? Also are the mounts at 90 degrees to the axel or is my other side bent? I am sure this is all caused from the shocks bottoming out and incorect bumpstops.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    With my new mounts the shocks aren't parallel to the axle tube anymore. The are mounted at an angle, but I am not sure it matters much.
