Broken lugnut studs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by _DeeVee8_, Nov 29, 2000.
  1. _DeeVee8_
    _DeeVee8_ 1/2 ton status
    149
    ok--it's been a while, I'd like to get an idea on what I can do to fix two broken studs on my left rear wheel axle(4 lugnuts are diametrically opposed but two are missing. I have to fix my e-brake for an inspection sticker anyway so I figured I'd be in there anyway--
    THE BOTTOM LINE: what do I have to do? Do I have to pull the axle to replace the studs? I have 33" bfgs and am afriad to put any kind of torque on the rear axles without the other lugnuts on it. 4 out of six isn't good, right?
    DeeVee8
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    At most, you'll have to remove the axleshaft. Try destroying the pieces left in there with a drill.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  3. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    I sheared a wheelstud on my Firebird. Could I just drill a hole and pull it out with an easy-out? I've never done this before either and am woried about the other 4 with all the torque my car makes.
    [​IMG]http://www.ncclassics.com
  4. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Relax.... all you gotta do is pull the wheel and brake-drum off, smack the broken pieces back thru the axle flange with hammer and punch, and pull your new lug-studs into place using a lug-nut and a few large washers by tightening the lug-nut. Just did all the rears myself this summer.
    "I'm not stuck...I'm just resting!"
  5. BigJim85
    BigJim85 1/2 ton status
    Sep 7, 2000
    113
    Lakewood, Colorado
    I can't really help, but on the subject of high torque and studs... My friend has a 69-70 Mustang Mach 1 with a nice 351 Cleveland in it. He pulls up next to a new Mustang and revs his engine and what not, well when the light turned green he wound up the engine and did a neutral drop and busted 3 studs off one of his rear wheels.
    <font color=red>Call my rig an SUV... And I'll tear your lungs out.</font color=red>
  6. KING K5
    KING K5 1/2 ton status
    Sep 28, 2000
    172
    Sacramento, Ca.
    How hard is it to "smack" them out? I have 3 that need to be replace on my drivers rear and I tested this on one and hit it pretty good about 5 times and it didn't budge! Is there a way to make this easier?
    Thanks for your help!
    Jeff (KING K5)
  7. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Take the rotors or drums, which ever and have them pressed out and get new ones pressed in. I just did this when I did my brakes.
    Don't you buy no ugly truck!
  8. EDdaTREE
    Feb 18, 2000
    1,253
    Austintown, OHIO
    If we're talking about K/5s...the wheelstuds are in the rear axle-flange,the brakedrum only slips over the studs before ya bolt on your wheel! I never had too much problem using a decent size ball-peen or a 2.5 to 5 lb. hand sledge hammer and a flat-nosed punch.Even did my front ones after I pulled the rotors off the frontend. Go buy your new studs and look at them-you'll see what holds them in is not that tough to BONK loose.
  9. _DeeVee8_
    149
    so the rear studs are a piece of cake! just whack them out- and you don't even have to remove the axle. well, then-- I'll do that tomorrow then-- I've been wary about putting the "hammer down" like i used because I only have 4 of the 6 on .
    thanks-- I'll try it--
    -Dv8
  10. EDdaTREE
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Didja get them out OK?
  11. mrivan
    mrivan 1/2 ton status
    Sep 10, 2000
    123
    Coastal Mts. Or.
    I use a hardened bolt next size smaller rather than a punch because I don't have a punch that big dosn't hurt to put a little penitrating oil on them first. Couple of smacks with a hand sledge should do it. let me know what the new ones cost ,I broke a couple on a nasty little Toyota motorhome one time ,parts store did'nt carry them and the dealer charged me like twelve dollars apeice for them........
    mrivan..........
  12. _DeeVee8_
    149
    they're still in therer.. i can't do it now-- its too frikken cold out..and i have no garage..
    i have looked into repacking my wheel bearings too--but the grease feels like an ice pak--
    i'll remeber your advice and do this job when i can find a heated garage....
    -dv8
  13. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Man, where do you live??? I think its too cold out at 50 degrees!!! Course I'm in So Cal!! It was frigging 80 degrees yesterday!!!
    ken
