Broken motor mounts
Discussion in '1992-Present Chevy & GMC models' started by retroblazer, Sep 24, 2005.
  1. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    280
    148
    Gustine
    I was debating on whether or not I should upgrade my motor mounts on my 94 Sub before I prerun Baja with it in Nov. I've never broken the mounts, but I noticed Autofab www.autofab.com had some extra heavy duty mounts. Not cheap at $185 bucks, but they sure look like they would hold up. So, how many of you have ever broken mounts?
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    is it 2x4 or 4x4 truck? if 2x4 then ha ha ha fun to do . just need to pull the coil springs and then you can get at the bolts to then remove them. the morons made it real fun. i did mine with out and it took me and a friend along with 2 wobble links and 2 extensions and lots of work on a lift.
    if i had only known this 2-3 weeks sooner as i had the front all apart . dammit.:crazy:
  3. retroblazer
    Nov 30, 2003
    280
    148
    Gustine
    motor mounts
    The truck is a 94 Sub that's 4WD. Also, anybody bust trans mounts?
