Broken Rear Spring Short Term Fix???
Discussion in 'The Garage' started by George_Pimpdaddy, May 5, 2005.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    :blush: I was working under my truck this morning and noticed that a rear passenger side leaf broke in half and half of it is out of the pack.
    im thinking that i could either remove the loose part of the spring or lift the truck up and place it back in the pack till i can pick up a 6" lift spring pack. Also how dangerous is this :confused:
    Im looking at picking up a 6" lift leafs through BDS or even a 4" inch shackle flip with a 2" lift in springs and how driveable would it be to only run the 6" lift int he rear and stock up front for a payday period (2 weeks :grin: )
    any help would be appreciated thank you :cool1:
    1989 Chev Blazer Silverado
    355/700r-4/241
    10 bolts posi in rear 3.73
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    you could drive with 6" in rear and no front, it'll just look real funny.
    if the rest of the broken leaf wont fall out, i'd just drive it that way til you get the new springs. go easy on it tho.
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    you will be ok for the short term. I drove with 2 broke on 1 side and 3 broke on the other. Couldn't even tell
  4. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    I drove around on mine broken for a month or two. Actually I never drove it on the road. I took it out offroading and never knew they were broke. Actually I realized they were broke when I wrapped my rear diff as the P.O.S. lift blocks busted. I know they were broke for awhile though because of the rust over the broken section. My advice baby it and drive it until you can get some. Get the shackle flip and 2 or 3 inch springs.
  5. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Broken Spring
    I Drove With Mine Broken As Well Just Beware That Axle Wrap Will Be Much Worse This Way. Drove On It For A Month And All Was Well Until I Forgot About The Problem And Tried To Spin The Tires A Little And Bound Up The Ujoint Because Of The Axle Wrap.
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Mines been broke for about a year, well, that's when I noticed it at least. Will be fixing within the week though.
  7. George_Pimpdaddy
    Oct 17, 2002
    1,306
    thanks for the info i lifted up the rear of my truck and placed the leaf back in now i just have to go order some lift springs and shocks :cool1: :pimp1:
  8. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    If you don't get to it fixed right away put a big hose clamp on it to keep the spring in with the others
  9. dyeager535
    26,982
    191
    Drove my K5 for a few years with one half of that same leaf missing. Never noticed much except it seemed to squat a bit more in that corner when backing up a hill. :)
