broken shackle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gpd4, Jun 11, 2002.
  1. gpd4
    gpd4 Registered Member
    Jun 25, 2001
    55
    St. Louis, MO
    I broke one side (outside) of my front right side spring shackle. I was thinking of just buying the replacement fron LMC Truck. Should I upgrade this, or just leave it like it is?
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Get the ORD Heavy duty shackles... /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    second vote on the ord shackles. and the new bushings with zerks will make your rig ride a bit better.
    grant /forums/images/icons/blush.gif
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    You broke it once. You should figure out why or else just upgrade it. Especially because with 9" of lift you may be tempted to get bigger tires at anytime.
    I have some shackles that I like, but I'm not sure where to get them anymore. They have three upper holes in them, all 1.5" from each other. That gives me the option to bump the front end up or down a little depending on circumstances. So with the hardtop on and on the street with the sway bar I keep it low. With the top and swaybar off for off-roading, I can move the front end up 3/4" or 1.5". The small change in caster shouldn't be a big deal off-road. I am using them with ORD greasable shackles with 1/2" bolts.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Here's what you want: http://www.offroaddesign.com/catalog/hdshackles.htm /forums/images/icons/cool.gif
    If cash is an issue, I've probably got some stockers laying around here somewhere. I could send you a couple of them for the price of shipping. /forums/images/icons/cool.gif
  6. gpd4
    Jun 25, 2001
    55
    St. Louis, MO
    Thank you all for the replies. Unfortunately, cash is ALWAYS an issue, so the stockers would be great! Send me an email at gpd4@dorrisco.com if you would.
    Thanks again
    Too many hobbies...
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Check your Private Messages. /forums/images/icons/cool.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My friend has those ORD shackles. They're nothing more than four pieces of steel with holes in them. If you want something stronger/longer, you can easily make it yourself.
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Actually, you get 4 pieces of beefy steel that have been gold zinc plated. /forums/images/icons/cool.gif But the kit also includes new upper and lower polyurethane spring bushings (I was shocked at how wasted my 25 year old stock upper bushings were!), new steel sleeves for the bushings and new bolts. For many bucks more you can get the rifle drilled greasable bolts. Oh yeah, they also come with really cool Offroad Design stickers attached! /forums/images/icons/wink.gif
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    George, today I shipped out the 2 straightest stock shackle brackets that I had. You should get 'em Friday. /forums/images/icons/cool.gif
  11. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    The shackles are longer than stock, have larger bolt than stock, and have the bushings to work with the larger bolts. /forums/images/icons/cool.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My friend has them. I know what they look like. They're still four pieces of gold metal with holes in them and a cool looking sticker. I may buy the bushings as they're a great idea, but I'll make my own shackles. I don't care if they're gold and I'm not gonna pay that for the sticker. But the bigger bolts/greasable part is great. I'm going to make mine 1" longer than stock I think too.
