broken shock mount Bracket
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dunc03, Nov 15, 2001.
  1. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    Somehow I broke my upper shock mount bracket on the rear driver side. The thing is riveted to the frame so I imageine it will be hard to find. Does anyone know where I can find this part. I've tried LMC and they don't have it. Is there any way to relocate the shock so that it bolts into the frame. The shock on the rear passenger side is fastened in this manner. Any help you can give would be great.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    it needs to be re-welded. I think Pugsley did this recently.... might as well go for the full relocation.
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Chevy dealer will have it, that's where I got mine - it was like $13...pop off the old rivets and reweld it on there...
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    kpanza is correct. I did the same thing recently. Went the the dealer and they had the part(that means they break frequently) bolted and had it welded in place.
    Derf00
  5. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i just changed mine, i had to cut the rivits off and use bolts to put the new one on.........i got the new one from a dealer ship I think that it was 13-14 bucks. to bad that it is a pain in the beeeeeehind to change
    high
  6. Dunc03
    May 20, 2001
    157
    Tyler,Texas
    I went to my chevy dealer to get the shock mount, and they said that they could only get it on the frame rail. Where did you get your. Whats the phone number, maybe I can get it from them. Thanks
  7. 91gmcjimmyCH_IL
    91gmcjimmyCH_IL 1/2 ton status
    May 24, 2001
    110
    Grayslake, IL
    I had the same thing happen and i still havn't gotten around to fixing it. I know you can get it from the dealer but I unfortunately don't know how to weld so I was thinking about just putting in a stud shock mount into the frame. probably won't be as good but the mounts will be moved eventually.
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    You have to go to a knowledgeable dealer(no offense to the one you went to) I had the same thing happen to me the first time. They told me it was part of the frame and couldn't be ordered. then I went ot the same place and talked to someone else and they ordered it for me, it was around $15...
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
