Broken Studs
Discussion in 'The Garage' started by big jimmy 91, Jul 14, 2005.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Dodge D 60 , from an 89 1 Ton
    The studs that hold the spring plate on the passenger side broke off in the housing :yikes:
    They broke below the surface of the housing about 3/16" , also uneven and jagged :mad:
    Now , what are my options other than drilling and an easy out :dunno: They look like they have been there since day one
    Are there any other options for repairing this "F" up? :thinking:
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I would do the drill and ez out. just use alot of pb blaster and they should come out
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    soak them REAL well with PB blaster or WD... for aday ot two with multiple applications of the stuff. then drill and ex-out...
    OR if you have a welder try doing a build up without getting the housing. then grab that with vice grips.
    Grant
  4. royjones
    royjones Trucker upper Premium Member
    Jul 6, 2005
    629
    6
    somewhere close to ya
    Hello
    Hello is the 60 out of the truck if so . do you have a machine shop up there they could probly get those right out . but if your going to do it your self get or borrow a flame wrench to heat it with once u drill or weld to remove it
  5. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
  6. Kiwi John
    Kiwi John 1/2 ton status
    Jun 24, 2005
    249
    West Sussex, England, U.K.
    Even if you're going to drill them your self it will be easier with the axle out of the truck, so you should try & find a machine shop who can mount axle on milling machine for best result,
    DIY: Be sure you mark centre of stud accurately. The thread spiral distorts the view and you must allow for this offset. Centre punch and then drill pilot hole with smallest drill possible. then you can progressively enlarge hole and correct for any off-centreness.
    LAWSON sell left-handed drill bits which 'bite' stud as they break thru into the space at bottom of stud hole and twist stud out as they turn.
    Snap-on do a similar gizmo which has a collet-type tap around a drill bit.
    In all cases use best rust-release / penetrating fluid u'v got.
    Good luck.
    P.s. If you damage thread when drilling, dont worry. You can drill the hole oversize and fit a 'Recoil' thread insert (Helicoil is similar). These are stainless steel and better than new. They bring the thread back to stock size.
  7. big jimmy 91
    Feb 21, 2004
    639
    :thumb: Thanks to everyone for their ideas :thumb:
    The diff is still in the truck so the broken studs are going to stay for now.
    M buddy just formed a grade 5 u-bolt to by-pass the studs for now and it seems to be holding very well :whistle:
    Just so you know this truck see's very little street use at low speeds (30 mph.)
