Broken Wheel Stud HELP!
Discussion in 'The Garage' started by 78GMCJIMMY, Jan 27, 2005.
  1. 78GMCJIMMY
    78GMCJIMMY 1/2 ton status
    Mar 29, 2003
    135
    Gresham,Oregon
    :mad: Well the last time I was at les Schwab apparently they crossthreaded one of my lug nuts.:mad: I was repacking my front wheel bearings and did the driverside first ,and then when i moved to the passenger side all hell broke loose:mad: (a stud snapped off due to lug nut being crossthreaded)!I have a spare wheel stud and am wondering wether or not it is safe to replace it in the garage without a press?:confused: I am sure I can do it(famous last words),just lookin' for pointers such as how to remove and install(ha-ha-ha)!Any ways as usual any help is greatly Appreciated.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You can punch the old one out and with a vice, squeeze the new one in. Put a tube or socket over the stud (deep enough!) and press it in but I really wouldn't advise hammering it in!
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I use an air hammer to drive them out and back in. If you don't have an air hammer you'll be able to do it with a regular hammer. Just don't try pulling it in with the lug nuts, that is crappy practice.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    If Tim's happy to hammer them in, then go ahead! He's prob done way more than me. I use a press 'cause I have one but if hammering works then go for it!:grin: But he's right about the drawing it in with nuts..it'll work but won't do the thread strength anygood.
  5. 78GMCJIMMY
    Mar 29, 2003
    135
    Gresham,Oregon
    Give me some credit guys
    :mad: Come on guys,give me some credit!Do you really think i am stupid enough to try and draw in a wheel stud with the nut trick:D (stupid trick anyway ha-ha-ha).Anyways I figured it would be safe doing one in the garage, but I don't think I would want to do all 24 that way.Anyways I guess I'll break out the BMFH(Big M****r F*****g Hammer),the vise and get to it! Thanks again to everyone who helps out around here!
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Just beat them good and solid. Then check the lugs for tightness after about 50 miles.
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    It won't be bad. I did 16 of them like that when I did my rear disc brake swap.
  8. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    I had a bad experience in a buddy's truck once..He forgot to beat all the studs into a 1/2 ton hub..yeh well..we lost some..well..ALL the lugs and the tire flew past us goin down a dirt road. Now that SUCKED!!
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I use a 3lb sledge hammer and a 1/2 Drive extension to drive mine in. Just use the same criss cross pattern when you drive them in so that the rotor seats properly and make sure all the studs are seated. I have done this to my truck and helped do it to other peoples trucks. No problem at all. It just gives your arm a workout, especially if you have an 8 lug axle.
    Harley
  10. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I have beat all of mine in with a 3 lb hammer and a 3/4 inch drive extension. However on my 14 bolt they were a PITA and had to go and use a presst o get them the last 1/8th of an inch in.
