Brother in law's EGR code coming up.................
Discussion in 'The Garage' started by BurbinOR, Apr 7, 2004.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Brother in law\'s EGR code coming up.................
    Guys,
    My bro in law's 95 Chevy 1500 keeps showing a code for EGR failure. He's been trying to get through DEQ with failure due to high NOX. We've diagnosed it to death, changed both the EGR and the EGR solenoid based on the info off my scanner. Before he brought it to me he had the TBI removed and the 'passages cleaned out', CAT changed, O2 sensor changed, to no avail. After we changed the EGR solenoid, code didn't come on for three days..........now it's back. Any ideas? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Re: Brother in law\'s EGR code coming up.................
    vacuum leak somewhere causing the EGR to do funky things?
  3. dyeager535
    26,980
    Can you see if the EGR is being commanded to "open" by the ECM when it shouldn't be? Perhaps the solenoid isn't getting power when the ECM tells it to, and the ECM can "see" that it's not operating right, so sets a code?
    On older stuff I'd say that isn't likely, but on a '95, there might be a larger degree of EGR operation monitoring. (EGR temp, etc)
  4. BurbinOR
    5,829
    Oregon
    I'll get him to bring it over and take a spin down the highway with him driving and me monitoring the scanner. Thanks for the ideas. /forums/images/graemlins/thumb.gif
  5. dyeager535
    26,980
    Found out from a friend just now that even the '88 Camaro setup monitors EGR temp for operation, so I guess it IS possible even on the older setups.
