Brown Bread install(sound deadener)PIC'S
Discussion in 'The Garage' started by BobK, Jul 12, 2003.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Brown Bread install(sound deadener)PIC\'S
    I installed a product called "Brown Bread".It's a sound deadening material that when compared to "DynaMat" came out ahead in tests.
    Anyhow I covered the whole inside of my Blazer with it.Inside the doors and the whole floor,firewall to tailgate.
    It took 2 days total to install.The product is a sticky tar like substance with a foil backing to it.
    You apply it to the area you want covered and then heat it up with a hair dryer or heat gun (this softens it) then roll it smooth with a 1" roller that was included.
    It cost me $120.00 for 1 roll.One roll covers 70sqft.I used 1.5 rolls because I covered EVERYTHING on the inside of the truck.
    Results:
    I like it.It makes the doors sound like a new car door when you close it...solid sounding!I have 6x9 speakers in the doors and the "Brown Bread" has improved their sound as well.
    I must say it is MUCH quieter in the truck now.
    I would recommend this product to anyone who wants some serious sound deadening.
    I got it on E-Bay.The guys sells it there or at his site here.$159.00 on his site.It's cheaper on E-Bay though,125.00.Do a search on E-Bay for "brown Bread" and you'll find it here.
    Here are a couple pic's
    This is how it's shipped to you.About 20lbs shipping wt.
    It's about 1mil thick,here's a close up of it.
    Here it is after smoothing it out in the door.A little bumpy as there was some rust inhibitor already on the door.
    The front done.I did end up doing the kick panel area's as well.
    The rear floor,bed walls and wheel wells covered with "Brown Bread"
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Re: Brown Bread install(sound deadener)PIC\'S
    I want to put sound deadner in my blazer too, but first I want to put some bedliner down so if water gets under there it will not rust. Looks good keep us posted.
    P.S. i found me some Gator Gaurd. Thanks /forums/images/graemlins/thumb.gif
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Good.Hope the dealer was close by.
    I laid down a coat of generic roll-on bedliner before I installed the Brown Bread.
