brown wire at harness
Discussion in 'Audio' started by wraenking, Feb 18, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    when i boiught my k5 and replaced the PO's stereo, the groujnd was hooked onto a brown wire from the factory harness. im haveing issues with my dash lights and courtesy lights not working because the fuse pops everytime i throw the lights on
    is this not a ground?
    im lost here?
    also, behind the drivers side vent there is a small block with some black wires. is this the ground to go into then?
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Are you just looking for a ground wire to tap into?
    If you are then take the wire you want to ground, put a connector on it and bolt it to the dash or other part of the body. Just make sure it's making contact with clean metal.
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    the brown wire wasa the culpret. thanks
  4. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    Yeh the brown wire is the parking,dash, ilumination wire. It shows ground when the lights are off and hot when you turn your lights on.
