bryan derby's 14FF disc brakes installed *pics*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mike reeh, Mar 22, 2002.
  1. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    bryan derby\'s 14FF disc brakes installed *pics*
    I cant say it enough- its effin amazing.. I got derbinators rear discs installed today, its better than factory. Now I can say SO long to drum brakes. the axle is noticeably lighter now too.. <a target="_blank" href=http://lagparty.org/~mike/pix/reardisc.jpg>Click Here</a> for a pic.. if anyone has any questions, or wants more pictures, let me know...
    bryan are you around anymore?
    mike
    [EDIT] <a target="_blank" href=http://lagparty.org/~mike/pix/reardisc2.jpg>Here's another shot</a>
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Re: bryan derby\'s 14FF disc brakes installed *pics*
    It's so purty......Look's good /forums/images/icons/wink.gif How much weight do you think you lost doing the swap?
  3. mike reeh
    Jul 23, 2001
    752
    San Diego, CA
    60-70+ lbs easily
    mike
  4. chris672
    chris672 1/2 ton status
    Jan 25, 2002
    554
    LODI, CA
    where did you get the brakes? Was it a kit w/ everthing included?
  5. mike reeh
    Jul 23, 2001
    752
    San Diego, CA
    What I go from derbinator was the brackets, a billet aluminum spacer, and grade 8 bolts with lockwashers...
    the only parts I had to buy was K20 front rotors ($22) and K20 front calipers ($12)... I re-use the original wheel studs..
    the only other thing thats gonna cost me a couple bucks is modifying the brake lines to connect. I think Im going to buy a length of line, and try to bend it how I like it, then cut it to the right length and flare it... Ive never used a flare tool before so I dunno how its gonna work out but I think Ill manage.
    oh yeah I have to buy brake pads too /forums/images/icons/smile.gif
    mike
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    A man after my own heart.....nice "frame up" you got going on there.....
    I slid my new 14Bolt under the rear of my frame just for fun, but I still haven't installed the "Derbinators" on mine yet.
    I'll be curious to hear how hard that tube bending/flaring is.....since I'm gong to have to do the same thing on mine!!!
    Nice Job! /forums/images/icons/cool.gif
  7. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    i have tried to flare my own brake line. Its a royale PITA. That was with a little cheapie tool from the parts store. It sortta worked, but seeped a little break fluid which was enough for me to scrap the idea. I ended up just buying a length of brake tubing pre flared to the correct size on both ends and bending it around enough to make it fit properly. It cost me a few trips to the parts store to finaly get the correct length with out getting one too long, but IMO its easier than making your own flares.
    Sparky
  8. A&P
    A&P Registered Member
    Dec 3, 2001
    88
    San Antonio, Texas
    Ahh, come on sparky, It's a piece of cake. I have a fair ammt of exp. in doing it. Just make sure you Have a couple xtra pieces of line laying around to practice with. When you get the line in the flaring tool, let the line stick through the other side about 1/8" and tighten it down. Use plenty of WD40, or your favorite penetrating lube, and turn the flare very slowly. When it starts to run all the way down just be carefull not to crush the metal sleeve. Also, before you flare the line make sure you deburr it. Use either a deburring tool, or some med. to high grit sand paper, or the combo of both. Make sure to deburr the line after you flare it too, just to make sure there's no sharp edges. Last but not least, make sure to put the nut on before you flare. I made the mistake one too many times in A&amp;P school making hydraulic lines. Have fun, and good luck.
    -Ben
  9. burbnthedsrt
    burbnthedsrt Registered Member
    Dec 19, 2001
    7
    arizona
    Where did you get the kit from? Please email at jrreason@earthlink.net
  10. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    How much was the brackets, a billet aluminum spacer, and grade 8 bolts with lockwashers
  11. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    WHere did you go to A&amp;P school?I went to PIA
  12. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    I also got miine from the derbinator, got pics, just not posted them yet, i think it was around a hundy.
  13. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    You are going to use flex lines to connect to the calipers, aren't you? It's actually the easiest way anyway, since front flex lines connect correctly to the caliper opening and have threads that match the hard line fittings.
