bubbles in my oil
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudRebel350, Jul 17, 2000.
  1. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    I checked my oil today and noticed when the truck wasnt warm there were tiny bubbles on the dipstick. I checked it again when it was warm and they were gone. Whats going on here someone tell me, I know this can't be too good.
    J.D.
    88 Gmc Jimmy
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Not sure I would agree with the water theory, maybe some condensation, but not radiator water. It would make the oil kind of a milky color and antifreeze would turn it green. (My oil turned green once and so did my face). Check under the oil cap for "cream". Other than that I have noooooo idea. Good luck.
    creepin' and crawlin'
    Jim
  4. Grim-Reaper
    7,385
    Atlanta
    Well if it was a BHG, Cracked head/block or any other way of coolant getting in your oil would have a chocolate milk look to it when the oil and water mixed and it would be more likly that you would see "bubbles" on your dip stick AFTER the engine had just been run. If your oil looks normal and your truck seems to have Normal oil pressure then don't worry about it. Probably just a bubble attaching to the stick as it was removed from the engine.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I've seen this before, too. My theory is that it's just air that's coming out of solution in the oil when it has been sitting for a while.
    I've seen this on dipsticks for my helicopters, and I KNOW there's no oil problems with them. So, I wouldn't worry too much .
    [​IMG] Semper Maintenance!
  6. det45
    det45 1/2 ton status
    May 23, 2000
    112
    San Antonio Texas
    I agree, there's nothing to worry about. I have experienced this with my wifes 96 cavalier. Ain't nuthing but a thang........
  7. MudRebel350
    May 20, 2000
    324
    N.J.
    My oil pressure gauge is sitting right around 30. From what I know and have been told this is good. Thanks guys. When it comes to my truck i want it done right. When its a riceburner I dont give a [censored].
    J.D.
    88 Gmc Jimmy
