Bucket Seat Conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Canuck, Oct 17, 2000.
  1. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    Howdy All;
    I picked up a set of bucket seats at a yard sale for $150.00 bucks. It's one of those aftermarket sets with the flip down middle seat that has a little storage unit in the bottom and a wooden drink holder in top. It's pretty damn nice. It's grey with a light grey spash across the middle of the seats. I know it retails for $1000.00.
    This set up is for an 86 full size pickup. I pulled the seats out of my 86 Blazer to see if they lined up to the bucket frames. Of course they didn't. Has anyone ever installed one of these in there Blazer? I think I need to fab up some mounting brackets. I don't think they sell the right backets for my application.
    The seat does move forward some, so I think I will still be able to access the rear seat. Mind you I removed the rear seat 6 months ago, so access isn't that important. I figure if you can't slip in the back your too fat and shouldn't be in there anyway.
    Any info would be appreciated.
    Canuck
    Blazer One, Deer None!
    Go Wide or Stay @ Home
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I looked into buying some aftermarket seats like that and some of the companies listed brackets for Blazers. Try getting ahold of salesco.com or steel horse automotive or best of all, the company that made your seats. Chances are, they will have the brackets that you are looking for.
    BTW: good find
    '85 JIMMY
    '90 paint/grill/trim 5"susp 33/12.5/16.5
    Fresh 350 B&M '87 TH700
  3. 82K5
    82K5 1/2 ton status
    191
    kansas city
    i added seats from a '98 suburban into my k5. they didn't even come close to the mounting holes of the factory k5 seats. sooooooo...... i just used some air tools and drilled my own holes. i only had to drill through one thing i didn't want to drill through underneath which was a heat deflector on the drivers side. other than that, they were a snap to install. as long as they fit between the doors.
    here's a pic.
    http://home.earthlink.net/~philmo1/seat2.jpg
    phil
  4. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    Just curious as I have been thinking of new seats as well. Why couldn't you just weld the old seat brackets or mounts to the new?
  5. Canuck
    183
    Sounds like a good idea, but, the stock bucket bracket is too high for the seats, or so it seemed when I tried them out just sitting on the bracket.
    Canuck
  6. rockosangel
    rockosangel 1/2 ton status
    Jul 11, 2000
    277
    Round Rock, TX
    We mounted 94' Suburban seats in our 82' Blazer..the holes didn't match up, but four pieces of strip steel and a few new holes, they mounted great...just make sure you plug up the old holes. We used two of the original holes to mount the steel plates thru for extra support. Took about 2 hours to do both seats, and they look great. Good luck on your project.... I would just sugguest fabricating some new mounts, but hey if you find a way to mount them into the original holes, I am sure we would all be interested.
    http://www.rockosangel.coloradok5.com
    http://www.rocko.coloradok5.com
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I've got some '99 Tahoe seats and the console in mine and I just drilled two new holes and they fit, but I need to make some brackets or something soon, because they move around a lot.
    90K5
