bucking blazer
Discussion in 'The Garage' started by kw48653, Apr 27, 2006.
  1. kw48653
    kw48653 Registered Member
    Sep 16, 2003
    86
    this blazer kinda bucks around when the speed levels out. don't have any problems when i'm accelerating or braking or switch down to a lower gear so that the engine stays under load.
    any ideas? is this the infamous "death wobble"?
  2. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    so your saying it happens at a steady cruise?
    what exactly is happening, Engine reving? or something suspension related?
    elaborate
  3. kw48653
    Sep 16, 2003
    86
    yeah, steady cruise. when i accelerate or otherwise put a load on the suspension one way or the other (braking or slowing) it goes away.
  4. 1-bad-burb
    1-bad-burb Registered Member
    Jun 23, 2005
    93
    west virginia
    first off, are you sure its not the road? with a blazers short wheelbase any little bumps can make it feel like its "bucking" and if your shocks are worn out it will just worsen the problem, also how are your tires? if they wear funny then you will get a little bucking, I've ridden in alot of trucks around here that bucked at steady speeds, and every single one had worn out tires and shocks, I wouldnt worry about it to much, from what I've seen around here with SWB trucks this is a commen problem, but you might also want to check your tires for blisters.
