buggy build thread.. F-ING TRANSMISSIONS
Discussion in 'The Driveway (build threads)' started by supersize75k5, Nov 30, 2006.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    since I always like to take pics, and doing alot of build threads or pic whoring is a way to get me motivated. I was in full swing on this 3 months ago..then I build the 86 and got a little distracted..
    specs..
    marv springers old fun buggy chassis, changes in wheel base, suspension, storage added and rear bench, things moved around to my liking and some bling in the mix.
    drivetrain: fi454, beefy fresh t-350 and ord doubler dually dana 60 front, dually 70 rear "need to locate one" big ol round tires, anf h1 bead locks, 3 link rear with swayaway 2.5 resivior coil overs, yj leafs up front.
    looking for insight and motivation as I go. pics on the way
    links of topics related..
    h1 vs h2 rim choice..
    http://coloradok5.com/forums/showthread.php?t=193336
    dually dana 70 disk brake talk..
    http://coloradok5.com/forums/showthread.php?t=203003
  2. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    Where's the pics? You can't post something like this without having the pics ready to go.
  3. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    :D 3 month old camera is being special ed right now, I might just go buy a new one I guess.:crazy:
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i thought it was suposed to be top secret....haha
  5. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    I happen to know where a HD D70 is lol.:D Waiting on pics as well. How far have you gotten so far.
  6. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    I have a DRW 70.
  7. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    whats the bcking plate to backing plate measurements, and where in california are you, I need to go to san diego soon anyways...im feeling in the mood for a vacation..:D
  8. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    El Centro is 45 mins from Yuma, AZ, 1.5 hrs from Sandy Eggo right on the 8 fwy. Bring yer truck and we'll wheel. :D
    I'll have to check those dimensions...it's bolted under my K30.
    Got a good 350? Or 400...or 454?
  9. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    I have one big block left, but I am saving it for a future hot rod project, I am sure I could find you a 350 or 400 easy
    do you want a drop in, a builder, standard bore, rebuilt?????:confused: are you wanting to build a 383?
    road trip:)
  10. AZPiNsTrIpEd
    AZPiNsTrIpEd 1/2 ton status
    Jan 24, 2005
    289
    3/4Tonsville
    Supersize, where's the old pic whorring dude we used to know?
  11. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    it currently looks like poop:o
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    prove it!:p:
  13. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Cheap/trade drop in so I can sell the K30 as a running 3/4 ton. Would have to be complete if it was anything but a 454 though. Truck was originally a Small block 400. Thinking yank the 454 to fix/sell later, yank the 70 and the 60, pull off the dually fenders, and put 3/4 stuff under it and sell it.
  14. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    time is money..how long do you want to screw with this thing?? sounds like you already got it for what you wanted, seems putting more money and time in it would be going backwards
  15. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Was gonna build it but got the Blazer for a deal and it's a better project - better shape, TBI, A/C. #5 cyl in the K30 454 is pooh. Need to sell the K30 for $ to get the blazer 1 tons regeared/locked. Can't sell it for much with a pooh 454, and I wanna keep the 60.
  16. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    well its a while later, and no pics
    I got itch and cleaned off the project, yanked the drive train and wiring brakes and everything off, then decided to move all the spring perches for the front backwards so my 600 bucks worth of highsteer and cross over will actually be of some use now..
    hell the thing even rolled and steered..
    yay
    I
    AM
    SO
    excited
    I
    just
    cant
    hide
    it.
    ok,now I am in a battle to finish this by the weekend of march 23rd for the brono stamped, I went last year and had a blast..have to register so this makes a good due date for the buggy..
    left to do list is includes only..
    EVERYTHING:crazy:
    I decided to go the the h1 bead locks, well for 100 bucks I decided why not, ill add rock rings, and some sort of pvc,nylon or something for the run flat.
    current thoughts, run my current standard 14 bolt.. or find a c30 van one, to be honest I am thinking this thing would rock at high speed or in the sand the a narrower rear.. but I need to choose soon. being that my 14 bolt is missing its guts..I may just find a van rear.
    rear.. startin to lean to the over lill on the hiems, evo maybe or summit
    other big thoughts are if I should just weld up the panels between the tube, seems more solid, I also have the idea kicking the seal this thing like a freaking boat..the last trip in the other rig I got my feet in ice water.. yuck
  17. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    got the 42's ordered
    ordered insert for the bead locks
    working on rock ring design
    and purchased paint for buggy
    sweeeeeeeeeeeeeeeeeeeeeeeeeeeet
    need to find a d-70..
  18. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    See my sig? How many 70s you want? :D
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    Post Pics!
  20. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Seek and ye shall find. :D
