Buick motor help
Discussion in 'The Garage' started by Muddytazz, Sep 4, 2005.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm working on a hunting buddies daughters very first vehicle. It's a 1964 GMC 2wd stepside, but its got a buick motor in it (I haven't determined if its a 350 or 455 or whatever yet). Anyways, the POS PO decided he was going to weld the motor mounts solid and the tranny was welded straight to the crossmember. Well the tranny problem is fixed as the tranny had to be replace. But I still have to figure out what to do with the motor mounts. Do I go with buick or gm motor mounts and just custom make the brackets/towers? Or is there a motor mount out on the market for this. Oh, this gmc originally came with a straight 6.
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    the year of the truck goes beyond my knowledge but there are companies that make chevy to buick motor mounts for dropping those engines into other vehicles. Its a set of plates that bolt to the side of the block
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The company you're thinking of is called transdapt. They make engine and tranny swap brackets for almost everything.
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Early Jeep Wagoneers used Buick motors. Might scout some salvage yards for pedestals off one of them, and transplant them.
