Build your own Anti-Wrap/Traction Bar---PICS
Discussion in 'The Garage' started by SCOOBYDANNN, Aug 29, 2006.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    Ok folks, today we are going to build a Traction bar/Anti Wrap bar (or what ever else you would like to call it.)
    Over all I spent
    $60 for Ruffstuff specialties traction bar mount
    $40 for Polyperformance Flex RE joint
    $10 for 5' of 1 3/4 x .120 tubing
    $10 for one more bushing
    and some time.
    Step
    1) Purchase material
    __A) Anti-wrap/Traction bar bracket from
    ____a)Ruffstuff specialties (one of three ways)[​IMG]http://http://www.ruffstuffspecialties.com/catalog/index.php?cPath=24?osCsid=ddab742f8693350db3570f73747c710c
    ____b) Off Road Design [​IMG]
    http://http://www.offroaddesign.com/catalog/bushingassemblies.htm
    ____c) RE Flex joint from www.polyperformance.com
    ______a1)
    2) Clean garage
    3) Mock up brackets ( i didn't use all of these brackets)
    (I did have to use 1/4" spacers on both sides of the RE joint to make up for the difference of the bushing.)
    4) tack weld axle brackets to axle (DO NOT finish weld them as you will need to adjust them for the final fitting.
    5) Place crossmember attachment point (varies (sp?) from all trucks and applications.)
    6)Attach shackle (every truck varies) to RE joint/bushing/heim
    7) Connect RE joint/bushing/heim to lower axle mount via. desired tubing. I use 1 3/4 x 0.120.
    8)adjust lower mount to be parallel to driveshaft by rotating axle mount.
    9)Connect upper axle mount to highest point possible on lower tubing.
    10)Paint and show off to fellow CK5ers so they can do the same.:D
    enjoy
    Dan
    Sun Desert Offroad
  2. 02turbogixxer
    02turbogixxer Registered Member
    Aug 1, 2006
    63
    Dallas, TX
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i need to make one for mine as well. looks good
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Nice job. Is that a 4" shackel?
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    not worried about terminating the upper link into the lower so far from the joint? I know I've seen folks before post failed bars that did the samething with thicker tubing.
    Boy it seems like I always have criticism huh?
    It looks damn good otherwise, and either way its gonna work great.
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    x2... 0.120 wall seems mighty thin. For this app I'd want 0.250 and I'd probably put "side plate" gussets over the entire length out of 1/8" plate or something too.
    j
  7. SCOOBYDANNN
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    yup
    i am kinda worried but i had progressed too far on my last peice of tubing to change direction. we'll see how it works. If it fails--build it again
    I love criticism. It helps me and others learn--I can either learn from the mistakes or back up the design. In this case I don't know what will happen, but I guarntee if it fails I'll let everyone know.
  8. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    A thought...
    You could beef up the tubing by using 1/4" thick angle iron welded along its bottom...
    like this... V
    I like the design..it appears the tubes might help protect the driveshaft from rocks while your scraping over them too!..:crazy:
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    good point on the driveshaft thing.
    glad you like the criticism I usually feel people take me as too much of an asshole in those situations, haha.
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Nice!
    The only concern that I would have is rotating the axle tube in the housing under torque. Seen it happen a few times. Maybe bracing over to the pumpkin would be a good idea.
  11. SCOOBYDANNN
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    I was definately thinking about that, but not too sure how to execute it. Any ideas?
    I was thinking of throwing a bead where the tube meets the diff but don't know if that would hurt it or help it seeing as how the diff is cast. I have seen it done before but it dosn't make it right.
  12. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    The diff is cast steel. You can weld it if you preheat it.
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    diff is cast iron. You can weld to it, and it will help, but its not going to be the strongest thing ever. Pre and post heating will be necessary for a GOOD weld. Something like a truss tieing both tubes and the pinion support ogether would be THE way to go, but its expensive and seeing as you have that setup for the traction bar, there is no reason for it. I'd ask a bit how folks have welded around the tubes then do that. I can't speak on it, I've never done it.
  14. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yeah I would at least weld the tube. It couldnt hurt at least.
    I have seen in one instance where it turned on a welded tube but it could have been a bad weld or who knows.
    Maybe brace off of the mount to the pumpkin a bit?
    That traction bar looks great and I plan on building one just like it this fall. :D
  15. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,812
    396
    Clayton Del
    Hey Sled Dog there are two kinds of criticism , one is the constructive type and the other distructive . From what I've seen of yours they have all been constructive and if other person can't see that then they are the asshole not you .
  16. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Does anyone know for sure if it's cast iron or cast steel?
  17. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    is it normal to do only 1? from what ive seen/heard is that you should run 2...
  18. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    2 might tend to impede flex. 1 is good if it's strong enough I think.
    You're probably thinking about the drag racing, sled pulling, or wannabe traction bars - put on to look cool (if you think that's cool :rolleyes: ) and make up for too much block lift.
  19. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    k thats what i thought, and ya i was thinking about drag racing, adn mud racing.
  20. 1BEATK5
    1BEATK5 1/2 ton status Premium Member
    Dec 15, 2005
    2,735
    32
    beaverton orygun
    hey scooby, i noticed that you ran both your exhaust pipes down the driver's side into one flowmaster. did you route the rt side around the oil pan sump, or under the trans? What kind of manifold or header design do you have?
    I have a 350/203/205 combo with a 2" up on the case. and now my exhaust is compltely hacked on the rt side to make it clear the shifters and the 3" front d-line. so I was thinking about some street rod headers that dump straight down and then routing the rt pipe around the sump on the oil pan for clearance reasons
