building 302 for the Z28
Discussion in 'Other Rides' started by tunedportk5, Mar 3, 2006.
  1. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    I'm putting back together the 302 for the 69, any suggestons for what cam and heads to use?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm a big fan of the Dart PRO-1 heads.Dart PRO-1 heads As far as the Cam go's, I'd give Comp Cams a call and see what the recomend.
  3. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    Those look good I wonder which would be a good application for me 180cc or the 200cc runners, or would going up to 215cc with the 2.05int. work on a mostly street application, but it needs to have the ability to blow the doors off anyone.
  4. sweetk30
    Nov 1, 2004
    25,529
    527
    horseheads , ny 14845
    those 302s rev quick. so i would say good air flow so it dont choke it self. call and ask them what thay recomend.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    id say dont touch the 302. leave the thing stock and pull it out. build up a 350 and put that in. the 302's are rarer by the day and worth a pretty penny. if you have the original parts it would be worth alot of money. just me though. 302's are killer motors in stock shape but as much as they're worth i wouldnt touch it.
  6. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    Thats whats in there now, is't a 350 with all the goodies putting out around 600 hp. The problem is it's not really drivable for street use. And the 302 was fun with the four speed so the block wasn't number's matching so why not. ​
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    is the motor itself numbers matching? doesnt matter if it is to the car but if the motor is original id keep it original cause its worth alot of money to someone. at the very least keep all the parts from it so you could resell it at a later date like it was originaly.
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    also a decent built 302 aint great for street uses either. the things rev so much and dont make a ton of torque (cause there short stroke motors) the only real way to run em is wide open:D
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    A good friend has a 302 in a 69 Camaro and it does fine on the streets. It's not a majorly heavy car, and he's not pulling anything with it, so it's not like a torque monster is needed. Sure, it has some deeper gears then latter Camaros, but 4.10's were fairly comman back in the muscle car days.
  10. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    Rite now I've got a chassisworks fab9 rear end w/4:11 and turbo 400 and if I swap in a 5 or 6 speed it should be a blast if I build the motor rite :eek1:
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'd run around a 190-200cc head setup with a 5 or 6 speed myself. Revving high and flying fast are amazing things ;)
