building a loft in a shop.. strongest and safest way?
Discussion in 'The Lounge' started by 55Willy, Feb 15, 2007.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    whats going to be the best way to support a loft 9' in the air. what about 2x6 vs 2x8's?
    it'll be spanning roughly 14' wall to wall. would a "patio" style wall bracket be enough?
    I will be running them on the 16" centers as the walls are already done that way. then sheeting the top with plywood of some type, will 1/2" be enough for flooring?
  2. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    2x6 would be pushing it a little
    2x8 16oc yellow pine no.2 spans @ 17'5"/Doug fir @15"9"/Spruce Pine Fir @ 16'3"
    5/8 would be better for the floor sheathing
    Don't forget Guard rails to keep you from falling over....:p:
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    cool thanks.
    co worker says use 2 x 12's and sheet it with 1" tongue and groove but he is also spending $1500 on a bath tub, not a spa or a shower combo...just a tub. so money isn't an issue with him.
  4. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    Sure you could go that route, but like you said lots of $$$$$
    Good luck with it.
    Larry
  5. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    what are you planning to put up there??
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    some of those 4x8 shop metal racks. the "gorilla" brand style.
    rubbermaid style storage totes with parts in them. there will be no motors or trannys going upstairs.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ask your co-worker to pay for your stuff and then you can go crazy building it overkill.
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what kind of ceiling is in the shop? trussed roof or?
  9. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    it's trussed. the peak is perpendicular to the door so dead center to the roof is 24' the eaves are 18' the door is 12' high.
    the floor area is 16' x 48' and my buddy has the one next to me and they gave us the okay to punch a mandoor between them.
  10. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    What about using some pallet racks on each end - then running your board supports between the shelving - that would be very cost effective & sturdy if you could racking for cheap
