Building an outdoor kitchen
Discussion in 'The Lounge' started by LKJR, Jun 10, 2005.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    anyone done this? have a couple questions
    I've got a nice BIG Stainless grill and I"m looking at building around it but not so permenant that I can't undo it later. (rent house)
    I'd like to bulid a fryer unit so I don't stick the house up when I do want to fry something. something along the line of a burner under a small rectangle tank. and get one of those commercial baskets. Then make a lid to fit over it to keep bugs and debris out of it when not in use but make the box removable with handles for emptying it and cleaning.
    Other thought was to make the burner adjustable so it could be adjusted to the top to use a wok on top of the same burner. But that's up for discussion.
    I've seen these things built of of 2x's and paneled with whatever and I've seen them built with CMU's obviously the latter won't catch fire but any other reasoning you can see? I'm thinking using 2x's will make it much easier to remove later if I have to.
    ...Discuss.
  2. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Is it Natural gas? Dont forget you might need to run a gas line,,,prob 3/4 from the meter underground if so. Dont forget about that if its not propane. Thats all i have to offer brother. :) Best of luck, Jacob :)
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    no the grill is free standing. with 3 doors under it. one for the tank and 2 for storage. so I don't intend to connect to the gas line. like I said, needs to be low impact. only connection will be a hose from the faucet to the sink.
  4. Storm Trooper
    Nov 24, 2000
    4,640
    Build it out of metal studs. No combustables or you'll burn the place down.
    Maybe use duro-rock/wonder board on that and then tile or rock it?
