Building rear 56" pack, do I use these? (pic)
Discussion in 'The Garage' started by dremu, Nov 5, 2005.
  1. dremu
    Feb 27, 2000
    15,957
    446
    East of San Francisco
    Should I use the leaf with the, erm, end bracket thingies (highly technical term) on them? Seems like they might limit spring flex, which might be good, might be bad.
    -- A
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    those stop you from bending the main leaf at full droop, so they are a very good thing
  3. dremu
    Feb 27, 2000
    15,957
    446
    Mmm. And seeing as I just spent all morning cleaning said main leaves and removing the bushings and sleeves, I want very much to keep them intact.
    Thanks for the quick response; out to the garage to shuffle leaves :haha:
    -- A
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    there are many people that dont run them, then there are more then extend them, this way you get more droop and the spring wont break on you.
  5. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Yes, use them. I don't right now and look what my spring does below. The mains are bent all to hell on mine.
  6. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    They also prevent the pack from faning out. If you want a quick way to clean the springs get a flapper wheel on the grinder.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    HELL NO, dont use them. I have mine in there but I removed the bolt. If you leave the bolt and when on a hard droop the spring will bend around that bolt. If you are worried about to much fanning clamp your main leaf and the one below it with some 2" strap and a bolt on either side. I have seen many springs bent by that stupid little bolt.
  8. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    DITTO
