building the top end
Discussion in 'The Garage' started by adamforsythe, Nov 23, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Well I am going to rebuild the whole top end on my 350 (photo below). The heads are stock with a little bigger then stock cam. With the truck breathing right you can hear a bit of a cam sound. But I want a little more cam sound. Plus I need to beat my best friends that is building a 302. Hear is what I am looking at
    Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 270/278, Lift .480/.498, Chevy, Small Block, Kit
    http://store.summitracing.com/default.asp?target=partdetail.asp&part=CCA-SK122433&FROM=MG
    I did not want a HOLLEY part on this engine but Edelbrock does not make a Dual feed 750CFM CARB
    Carburetor, Model 4160, 750 cfm, Square Bore, 4-Barrel, Vacuum, Dual Inlet, Silver, each
    http://store.summitracing.com/default.asp?target=partdetail.asp&part=HLY-0-80508S&FROM=MG
    Cylinder Head, S/R Torquer, Cast Iron, Assembled, 67cc Chamber, 170cc Intake Runner, Chevy, 302/327/350/400
    http://store.summitracing.com/default.asp?target=partdetail.asp&part=WRL-042660-1&FROM=MG
    How much HP would I be creating and would this be a good set up for a truck that will not see rocks or much low RPM driving?
    Adam
  2. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    One more thing with that set up would I loose or gain HP if I went with a Dual carb tunnel ram intake manifold? How big would the carbs have to be? 375CFM each?
  3. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    a tunnel ram of any sort would be a horrible mismatch with a mild 350 like that
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
