Built 10 or Dana 60
Discussion in 'The Garage' started by stockk5, May 31, 2005.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Alright well i recently got a 14bolt rear end, i am gonna put that in my truck at some point. i mostly do mudding and sandy hill climb stuff. Not to big into the rocks but trails seem fun.. i havent done a ton yet though. I was thinking if i can get an 8lug conversion for my 10bolt. and some cromo shafts w/ the gearing on want in it do you think it would work well enough? I am not very hard on my stuff. Like i said im only mudding and sand dunes, i plan on getting 38" tires at some point as well. This is my DD and is going to be for a while. I am a poor college student so i cant exactly afford a D60 right now as well. I have yet to break anything on my 10bolts but i know if i want bigger tires i atleast have to upgrade the rear. So would a 10bolt hold up u think to 38's used for mudding and such? what would you guys do?
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    10 bolt on 38's and mudding, it will break eventually, convert it w the stock shafts, and save till you can get a D60, plus, a deal on a D60 might come along while your waiting, I found 2 D60's for $1300 for the pair :D , that was a good deal there
  3. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    there was just a post on here where a guy was running 3/4 ton stuff with upgraded shafts and joints and he was running 42s.
    if you are easy on it you should be ok.
    right now im running 36s on 1/2 ton drivetrain and i havent broken a thing. i hit stuff hard to, but i only really do mud and some small trails.
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    You'll be fine, just carry extra u-joints and possibly shafts. :D
  5. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    Dana 60
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    What he said, siiiiiiiiixty! Cant beat the bling factor, course they are expsensive but no breakage and your rig will stop on a dime with those huge rotors and calipers.
  7. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    mud and sand = low traction, the 10 bolt should hold up.
  8. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    I beat the hell out of my stock 10-bolt running 39.5 IROKs and so far no breakage. If you want it to last though don't lock it up, leave it open, lots less stress on it. Sucks for traction but it is a tradeoff. I got stuck in a deep sticky mud pit last weekend and got out eventually with lots of tire speed. The trick was to let off the go pedal as soon as the 10-bolt was about to catch traction out of the pit. I am in the same boat, can't afford a D60. My truck has a 12 bolt in the rear also with a lock rite. A lot of people will say this is lame or whatever, but my truck has gone through some gnarly stuff and no problems. I have trimmed off a lot of metal though, so I weigh a lot less than a stock K5 now, that is another way to get away with IROKs on 1/2 ton gear. :D
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Based on what you want to do with it, convert the 10B and throw soem chromo shafts in it. Leave the diff open. You should be fine. I have run 38's on 1/2 ton gear for years w/ no issues. I have a front gov-lock too. I beat the hell out of it. I have never had any issues and I'm hard on my stuff. If you lock the front, you will have issues as soon as you start trying to make tight turns (anything close to full lock). Go easy on the skinny pedal in the turns (when in 4WD) and you should be fine. The other trick is to know the limits of your rig and stick to them if you don't want breakage.
  10. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I would convert the front and leave it open and save my money for the 60 I ran 38s for a while with a stock 10b in the front and never had any problems. Just remember to check the ball joints and wheel bearing more often than you normally would
  11. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    I say chromo the front with ctm's if you lock it. If you leave it open then stock should do just fine with your application. I am also another one beating the hell out of their truck with a locked 12 bolt rear and open d44 front with 35's and have only broke one axle in the front.
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if you're gonna wheel some trails and you want to regear, I'd go d60. If you aint gonna regear, a 10 bolt with chromos would prolly work for ya.
    the cost of regearing, adding a locker and chromo shafts for a 10 bolt is starting to add up... if you want to go that hardcore, just go 60 early and be done with it.
    j
  13. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    agreed
  14. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Save your cash and just get a D60. I've never heard anyone regret getting a D60. I have heard people regret upgrading their 10bolts with all the special axle shafts and stuff and still breaking. Then they get a D60 and say they wish they would have went D60 right from the start. Listen to them.
  15. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I guess people who went from dana 60s to rockwells would have regret it :haha:
  16. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Dana 60 just because of the tire size you plan.
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    not when they sell their built D60 for mad ca$h....
    j
  18. 79chevyk10
    Dec 14, 2003
    612
    Central Coast
    And not if you have already regeared and grew into the sport. Got way to much invested in my D44 and 12 bolt to turn back now until they break alot. I can deal with one failure every once in a while. IMHO.
    For mud and sand while keeping the front open I think he will be fine.
  19. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Also the savings in unsprung wieght will be way better in those conditions. :cool1:
  20. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if there is one place not tp save weight, its the axles. Almost as a rule, heavier is better.
    j
