built 4L60 in a 91 1/2 ton?
Discussion in 'The Garage' started by 91GMCSuburban, Feb 11, 2004.
  1. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    What are my options?
  2. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    Re: 4l80 in a 91 1/2 ton?
    OK, found a thread that basically stated 4L80e is an expensive option. So, how about tough built 4L60 (700R4).
  3. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    ttt
  4. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,853
    280
    Truckee, CA
    People say they hold up alright if you run them from the start with a HUGE tranny cooler, but not sure if that was referring to stock or modified rigs...
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    First off, is the tranny already blown or is it in good condition still? If it is I would run it until it does blow because the 87' later th700's are decent trannies.
    If it is blown then take it to a reputable tranny shop that knows WTF they are doing. You should already have a 10 vein front pump, I would use an aftermarket sun gear(this is a weak link, you loose rvrse, 1st, and 3rd when the splines break loose from the shell), extra clutches in the 3/4 pack, kevlar clutches and bands if needed, modified valve body for more flow, late model rear sprag(another weak link, odopted part from a th350 when it was designed), late model accumulater springs, a good blueprinted torque converter with a billet center piece, and your choice between a corvette servo or shift kit. This is all that is done to mine that I can currently think of and I am very confident in it's strength because it has seen some rough use and has never skipped a beat. /forums/images/graemlins/waytogo.gif To give you a ballpark idea, my th700 is probably about as strong as a th400 with a good shift kit. /forums/images/graemlins/thinking.gif
    Oh and don't forget to run a good sized stacked plate cooler ALONG with your factory radiator cooler.
