Bulding a TBI motor
Discussion in 'The Garage' started by mudhound72, Mar 15, 2005.
  1. mudhound72
    mudhound72 1/2 ton status
    Feb 15, 2005
    474
    Oshkosh, WI
    I am in the prosses of bulding a TBI 350ci
    I am just looking for your thoughts ideas good or bad I want to learn form your mastakes
    Here is what I am thinking of using
    350 4-bolt main 10.0-1 compression forge pistons B+B
    Vortec heads
    2 1/4 Ram horn manafolds
    TBI-Vortec performance intake
    BBC TBI Will this be to much or not enough
    Pref cam
    Reburned chip how is this done, can I do if and if so were do I find the equ to do so
    I am trying to think ahead so I can get the parts when I can afford them
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You are going to have fun trying to get a chip that will work with 10 to 1 Cr and the cam. If you do it It would be best to spend some time on a dyno with a good chip man to get things right. So things dont go BOOM! It will Cost some $$$ tho
    Why dont you just buy a 330 350 HO GMPP crate engine. lots of people make aftermarket chips for those. Be a lot easier and cheaper. All you are loosing is a few points of CR. Stock 454 TBI, aint gonna support much more HP than that anyhow.
  3. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
    I did think about buying a GM creat motor but the one I am working on bulding is going to cost me about half of a creat. I also have connections on the dyno end on the deal, just will require a little convising to use it. The biggest prob that I have is that I want to learn how to burn the chip cause I dont know anyone that can do it.
    Hech in a week I may change my mind and stick with a Quad :dunno:
    I want to run TBI, but dont know if it worth the PITA that it will be to set up. That is why I am asking here cause I dont know anyone that has messed with it yet
